Hi, I have been using ZW but the app has been abandoned by the developer since 2015. KWGT comes up as a viable replacement. I like to keep looks, consistent across my phones. I was wondering if KWGT can import my ZW widget? If not, can it replicate it?
I just loaded KWGT. First off I was unable to set the widget size equal to my ZW dimensions. This may be my ignorance of the app, and I'll look further into it.
Attached is the widget I'm trying to replicate. As you can see, the weather function no longer works.
