Image Path issues
I’m trying to get some random images from this folder, but I don’t understand what I am doing wrong. I have tried all sorts of file paths including using “sdcard”, “storage/emulated/0”, “file:///” but none seem to work.
Phone is a zfold3
KLWP is 3.74b328615
in newer android there’s some file access problem, due to tightened security. try putting them on kustom folder or use flow instead.
Well technically this solved my issue of finding the correct path, but no matter what I do I can’t get the images to actually show up now. KLWP see the path in the editor and correctly chooses a random image, but nothing actually shows up.
Try using Flows and see if this will work for you. You can use the information from the link below as a guide.
