Greetings developer,
I would like to throw an idea in here.
It would be great if every global variable can be renamed.
I think this is technically impossible (otherwise the feature would already be there), but even it is possible, it wouldn’t be all that useful, since you’d have to check where it is used and replace all those instances.
Just my 2 cents…
Hi RonC,
Noted and thanks for your response.
