I found an older theme I would like to use. The creator suggested Iconzy for the icons but it doesn’t work on the latest Android and KLWP versions.
Someone on Reddit suggested I move the icons from the KustomIcons folder Iconzy created to Kustom/icons but when I do that, the icon disappears from KLWP/Iconzy. I’m new to Iconzy so any help would be appreciated. Thanks!
no need to do that, doing so (moving icons) from that folder will break iconzy(will not show icon) if you do that. also you have to choose icon and save it in iconzy first which I think you did by the looks of the formula and that is the process. I’m not sure there was i think bitmap save issue for the klwp or kwgt file not saving it on older version so, if it’s older version’s klwp file you might have to reselect the icons other than that it should be working fine. after reselecting icon images, it should work fine whether it’s through the iconzy or klwp(android file picker). if it’s still not working I recommend you to check “KustomIcons/Icons” folder in internal storage of phone to make sure the icons are there, and I had issue with iconzy in past where sometimes it was not showing icons, I figured it was the android system putting app to sleep so I also recommend whitelisting it from battery save menu and iconzy’s app info → battery section. if it’s still not working as intended, could you please share the theme link and your KLWP, android version so I might be better help in solving the issue. I’m on android 12 and latest android is android 14 but klwp works same but not sure about iconzy I had to download apk to sideload in my phone since playstore didn’t let me install older android version apps.
Android 14 won’t let Kustom into the Iconzy folder (only 1 folder allowed, which you need to be the Kustom folder otherwise nothing will work).
That’s why my workaround is to put the images in the Kustom/icons folder.
ooo but i thought $br$ returns the image directly to kustom app never knew it just returns location of file then kustom have to access that file. nice to know.
