Icons from Iconify source stretch when padded
(Version v3.81)
When using icons from Iconify, padding them stretches them instead of adding padding.
Maybe useful to know - when placing an Iconify pack icon in an Overlap Group instead, and adding padding to the overlap, it doesn’t stretch the icon.
The issue does not exist for positioning icons in root
Icons from Storage work correctly
+1 padding is working weirdly in the latest versions.
Actually, the padding issue isn’t related to Iconify specifically. It’s a known bug in the latest Kustom versions (it started a few updates ago, while older builds worked fine).
To fix it, put your icon inside an Overlap Group and move the Overlap Group itself not the icon.
