Yes, following example is for screen 1 but you can do the same for the others:
- Add a SHAPE module to the root, set shape to "Rectangle"
- Select the width option and turn it into a formula using the calculator icon on top, enter the formula $si(rwidth)$
- Select the height option and turn it into a formula using the calculator icon on top, enter the formula $si(rheight)$
- Now, go to the FX tab, select Gradient -> Bitmap and place your image
- Finally go to the "Animations" tab, add one animation of type "Scroll", tune params so the rect will only stay on screen one and scroll away
