i cant use kapk
it gives me this error everytime
Mmm, this is pretty strange, which version of Android are you running? Did you try to use your own keystore?
6.0.1 im using the keystore the app generated
Same problem. Both with automatic and manual.. Android 6.0.1 MMB29M. Ready to provide additional information
Bingo! I solved my problem by changing the type of my keystore from the JKS to BKS-V1 using KeyStore Explorer
I know this might me too old, but just wondering KAPK is not working and Kustom Konsole is not working either. I am using Z Fold 7 One UI 8.5
KAPK is giving me this error org.kustom.apkmaker/cache/out-unsianed.apk: open failed: ENOENT (No such file or directory)
And
Kustom Konsole must of the time is giving me NETWORK ERROR, and apk stays in queued.
If is not too much to ask. Can you help me?
Hi @Zeus_H ,
AFAIK the KAPK is no longer used and the Kustom Konsole app it’s the twinned replacement.
However, I am not able to sign in to Kustom Konsole using my Google Account and some other people too. I am still waiting for the developer to troubleshoot this issue.
