Since updating to HyperOS 3 the System MaterialYou Accent Color no longer gets the right color, only green.
And since HyperOS 2 I’m also having trouble with the touch areas not being precise but that’s been reported before I believe.
Thank you!
Thank you!
Okay glad it’s not just me. I’m using One UI 8.5 Beta on a Samsung Galaxy 25 Ultra and I thought it may be due to the OS. Same issue all of a sudden here. Been troubleshooting for like an hour and gave up.
What Home Screen Grid are you using? In my experience with HyperOS 2.0, grids like 5x9 often break touch precision because of how the Hyper Launcher handles scaling. I recommend trying 4x7 it seems to be the most stable for kustom. Could you check if switching to 4x7 fixes the touch alignment for you?
Regarding the colors: is it just si(sysca) that’s failing, or does si(wpcolor) (which pulls directly from the wallpaper) also return only green? It’s important to know if Kustom can’t see the system palette at all or if it’s just the accent extraction that’s broken.
Wpcolor is working thanks!
4x7 layout seems to work better but I’ll try it out more thoroughly when I get home tonight!
Do you think the failing si(sysca) will be addressed?
Just updated to 3.82 and kwgt still gets the wrong si(sysca) wall colour in HyperOS.
