Hello. I bought a new icon pack in the playmarket, and I don’t know how to use them in the creation of a new widget. How do I integrate the new icon pack into the program?
Hi Leon,
When you install a pack you should be able to find it in the explore section when loading a preset under “Installed Packs” like image below. If its not there ensure you have no filters set.
Thank you. Okay, I’ll try to review all the parameters. If I don’t figure it out, or something doesn’t work out, I’ll have to ask for help again.
