Hello. Been using KWGT for a number of years. I have a widget that shows how many days / hours till battery discharge/charged. It uses the pre-defined formula for text so shows as ‘1 day from now till discharge’ etc etc. However I’d like to tailor it to just show the number of hours/days - eg ‘2 hours’ or ‘1 day’. Can someone tell me if it is possible and how to do it?
If you look at the formula in Battery Info underneath the one you are using you’ll see one (“Discharged in 20 hours”) that’s easy to modify for whatever you want to say.
