The only thing that works when it freezes is restarting, but is there a faster way?
I’m running Nothing OS 4.1, Android 16, Nothing phone 4A and KLWP version 3.82b621115
Go to KLWP’s app settings >> Advanced options - turn on “Disable Parallel Rendering”. See if that helps.
Thank you, but that was already enabled
I figured out that was causing it. In case it helps anyone else, tapping and holding on the home screen and pressing customize was causing the wallpaper to freeze and the only way to get it back was to set a different wallpaper and then set it back to kustom. I just avoid pressing customize now.
