How to make global variables?
On the Base or Root level of your project you should see ITEMS BACKGROUND LAYER
POSITION near the bottom of your screen. If you put your finger on that line and move your finger to the left, you should see GLOBALS FLOWS SHORTCUTS. Tap the GLOBALS so you see the red underline and then you can create global variables.
