How do I go about using a widget (wolf clock) on the lock screen?
I'm new to this and was wondering if there was a way to use the wolf clock widget on the lock screen?
Your lockscreen(I think that you are speaking of your stock lockscreen) need to allow to put widgets in it. If not, that's not possible.
I'm running on Nova Launcher Pro. I dont see anything regarding a lock screen
Hi MatthewπŸ‘ In what lock screen you want to put the widget?
Not sure I understand what you mean.
I only have one lock screen. The nova launcher lock screen
Nova launcher allow you to use the same wallpaper(the image) in your screens and in your lock screen, but you can't put widgets in your lock screen unless the lock screen that you use allow users to put widgets in it.
Nova launcher is a launcher not a lock screen
Ok, I just wanted to see if I could use wolfie 093 or wolfie 094 clock widgets in a lock screen
If when you wake up your phone you see one page of the launcher, you can put the widget in this page. If when you wake up your phone you see a lock screen, probably is your stock lock screen that come with your phone, in this case you can't put a widget in it.
Correct it is a stock lock screen but I do have KLCK pro now
Ahh ok, if you have Klck now give me one minute and I go to make a test and give you one idea. Do you know if Wolfie widget is locked or not?
Unlocked I believe. It shows all the coding
Ok, to test if it's unlocked you need to change one color or add what you want and try to export the widget with other name(don't forget to change the name if not you overwrite the widget😑🀣)
It must be locked cause when I click on paint it only let's you choose to change the color to one of three preexisting colors: hours, minutes, or text
To use the widget in Klck, you need to go in your phone to the Kustom folder, Widgets, and copy the widget that you want and paste it in Kustom folder, Lockscreen. Now you need to change the extension of this copy from .kwgt to .klck
Now you need to go to Klck app, and load the widget that now is a klck preset. Put the color that you want in the background and in touch set the touch to unlock the lockscreen DON"T FORGET TO SET THE TOUCH ACTION TO UNLOCK THE LOCKSCREEN......
Touch
Type (what you like)
Action Kustom action
Mode Unlock screen
Don't forget to set the unlock actionπŸ‘πŸ˜πŸ‘
Set the lockscreen in the Klck menu and test itπŸ‘
This are globals don't care. Try to put a text and try to export it. This is the question if it allow you to export it
I'll give it a shot. Thank you for your help. Its much appreciated
Good πŸ‘πŸ˜ if you need more help, come here again.πŸ‘ŒπŸ˜ƒ
Holy crap dude...after walking me through this, you should be able to teach physics to chimps.
It worked. You sir, are the man!
Jajajaja ohh you are making me laugh πŸ˜‚πŸ€£πŸ˜‚πŸ‘πŸ‘ŒπŸ‘
Good good that you can make this work. Good luckπŸ‘πŸ‘ŒπŸ˜
