How do I get notification icons to show up?
I'm trying to get the icon of the notification to show up, but it just shows the file location. What am I doing wrong? I attached a screenshot of what it looks like.
You need to use that formula in a Bitmap preference, so, for example:
  • Add an Image Module
  • Select the "Bitmap" preference and click the calculator icon to make it a formula
  • Insert the formula you used to select the notification icon
  • Done!
I dont understand this. Can i display the icon in a text box? Can you give me an example code please? Thanks.
