Hi!!!
How i use the Fonts with Swash Characters in KWGT ?
Hi!!!
You can download the .ttf file to your phone.
Put a text in your widget, enter the font to select one, in the top of this part you can see a folder icon in the top, tap in it, this are going to open your phone card, navigate to the folder that you have the .ttf file, tap in it, this are going to save this file to the Kustom font folder and load the font in your text.
See the caracter under ---nda --- ? its came hide, a swash font
Oohhh, yes, I don't know if this fonts can work in Kustom apps, you can try to put a second or third empty lines in the text and see if this can work.
