Help with kwgt
I posted in the kwgt section of reddit but got no response so I’m trying here.
I have a kwgt that shows information as shown int the two pics in the previous post. After a few hours, the text becomes left shifted.
The text is extracted from a google sheet and sent to KWGT line by line by a tasker task. Rerunning the task when the data is shifted gets the data back in the correct position.\
The phone is Samsung Fold5 using Nova Launcher.
I thought maybe it had to do with different resolution when folded. But it happens when the phone just sits and isn’t folded. Also, after the data is shifted left, I can run the tasker task with the phone folded and the data is then in the correct potition.
Can anyone help me figure out what’s wrong and get it fixed?
Dont see any way to post pics. The text all becomes shifted to the left. Depending on the length of text some text may even be cut off on the left side.
Maybe you can share a copy of the preset or a portion of it that demonstrates the issue? That way, others can try to reproduce it and help you more effectively.
