Help! Restoring lost KWLP preset
Help
So i had an old kW l. P preset, that was really good and I worked really hard on it.I clicked create to create a new preset and but now I can’t find the old one that I made. I think I made a restore point a long time ago, but i’m not sure. i replaced it with the new 17 minutes ago. Is it still salvageable? And where can I find old preset? It is not in library and I couldn’t name it
If you exported your preset, which I hope you did, they should be in the “wallpapers” folder. If not, check the “autosave” folder for partial save.
