[HELP] KWGT Based Questions
[HELP] Questions ABOUT KWGT!
Hey Kustom Forum.
I have been using KWGT and KLWP to personalize and customize my homescreens on my Android. I updated the homescreen that I had before, as a small side project. I think that it came out excellent. I have been getting into adding more than one (1) homepage to my homescreen with multiple custom widgets that aim to combine aesthetics with utilitarianism.
While doing this. I ended up stumbling upon the concept of “Komponents”. Which seems to be the one part of KWGT that I don’t really understand how it’s used and for what or why it’s used. Can someone break it down so that I can understand?
I have ALSO been trying to create icons (weather, battery, etc.) that change based on certain parameters or guidelines. But so far I haven’t been able to do that either. Can someone break that down for me?
Thank you!
it’s like portable addons for widgets/klwp which you can add into widget. to clarify widget, you have to import or create new and if you want to add something that is already made-up export it as komponent and then you can import it in existing widget without having to lose existing widget elements.
