I lost the damn files and I’m sure at one point I logged in on the settings page and had it save my exported wallpaper.
One more question, is there an easy way to convert parts of a KLWP theme into a KL widget? Because I want to use this ‘live background’ app and get like a cool lava background, but just add the functional parts of the theme on top (via widgets). Or is there a way to have something like that integrated into KLWP?
As far as I know, exported/saved presets are located under the Kustom installation folder:
wallpapers folder for KLWP presets
widgets folder for KWGT presets
lockscreens folder for KLCK presets
watchfaces folder for KWCH presets
komponents folder for Komponent presets
, and not in a cloud storage (also, Kustom doesn’t provide a cloud storage for its users). Unless you regularly backup your preset files, by copying them to an external storage and/or to your Google Drive, you can’t have those lost files back.
A Google Account is needed for Pro license checking and for integration with Google services, such as Google Fit.
Unfortunately, there’s no direct way to convert parts of a KLWP theme into a KWGT widget. You’ll need to manually recreate the elements in KWGT by copying their design and functions from KLWP.
