[HELP] Can't import iconfont into KWGT
I’m not a very tech-knowing person nor is English my first language, so I hope I can make myself clear enough.
I’ve been trying to add an iconfont icon pack to KWGT all night, but nothing I’ve found has worked so far. I have both .ttf and .json files installed in the “icons” folder, and yes they have the same name, but then when I click on the icon pack selector and I try to search for icon packs on the “Storage” page, nothing shows up.
By the way, I don’t have a “Kustom” folder either. Instead, whenever I export widgets they save to the “widgets” folder inside another “Widgets” folder (/storage/emulated/0/Widgets/). The “icons” folder I mentioned earlier is also inside this folder.
@ethan.lmn :
Do you remember which folder did you install your KWGT app to? Normally, Kustom apps (KWGT, KLWP, and KLCK) are installed under the same Kustom folder, located in phone’s internal storage.
I think your issue with the icon pack is due to the incorrect folder you use to place the icon pack files.
