Device Info:
Model: Samsung Galaxy A53 5G (SM-A536U1/DS)
Android version: 13, OneUI 5.1
GPlay System Update: August 1, 2023
Android Security Patch: September 1, 2023
Synopsis: When editing an LWP (especially animations), for longer than 2-3 minutes, the application’s UI frame rate will drop significantly, from a perfect 120hz (On this device/display) to 10 or even lower. Performance does not return to normal unless user closes/suspends the app, and reopens it. This occurs consistently and constantly, and appears unrelated to user actions (performing actions that would typically be simple to do, such as creating/deleting objects or editing shape properties will result in the same issue). Issue has been happening since I got this device (Approx. March of last year). Problem does not occur outside of the editor/on the home & lock screens.
Expected Behavior: Consistent application performance, without the need to constantly close/relaunch KLWP every 2-3 minutes.
