I can’t only get certain texts to display for example, my custom greeting, date, and time will display but not weather, next event or my steps data and everything is using the same font. It will do this if no matter if I use complication data or the normal input.
You probably didn’t get any answers because you didn’t provide enough information. You should show some of the formulas that work and the ones that didn’t.
Thank you for replying. The issue has been resolved with a kwch update a while back
