Is there a formula for slowly changing color, perhaps from blue to red, with the transition occurring over a few minutes or an hour? Additionally, can the color change be triggered by a specific time, such as 10 a.m.?
The information in this Reddit thread might give you some information on how to make yours.
https://www.reddit.com/r/kustom/comments/39ltnr/how_do_i_set_which_colors_to_move_through_based/
Sorry, Im a bit lost with the explanation on Reddit. Could you break it down step by step and make it simpler for me to understand?
Below is the example provided here. This will change the color from blue to green gradually. The color will slightly change every second until it becomes blue.
**$cm(0,df(ss)4.25,255-df(ss)4.25)$
If you want this to happen in the span of an hour, you can slightly modify the formula like this:
**$cm(0,df(mm)4.25,255-df(mm)4.25)$
