GPU Shader FX (Layer -> FX) rendering bug (vertical tiling and noise) on Android 16 (OnePlus 12)
Bug Description:
When applying any Shader FX (such as Scanlines, Vignette, or CRT) under the “Layer” tab → “FX” → “Shader” of an Overlap Group, the rendering of the entire group breaks.
Specifically, the group contents (including all child shapes and text) are repeated/tiled vertically multiple times, and a vertical strip of black-and-white static noise appears in the center of the widget.
When the Shader FX is set to None, the widget renders perfectly fine.
Device & OS Information:
  • Brand/Manufacturer: OnePlus
  • Device Model: OnePlus 12 (CPH2581)
  • Android Version: Android 16 (SDK 36)
  • KWGT Version: 3.82b619510aosp
Steps to Reproduce:
  1. Create an Overlap Group with some shapes and text.
  2. Go to the Overlap Group’s “Layer” tab.
  3. Change “FX” from None to any Shader (e.g., Scanlines).
  4. Save the widget and check the home screen.
  5. The widget layout is duplicated vertically with a vertical noise stripe in the middle.
Thanks for the report, this one was real and it is fixed now.
The shader was getting the screen height while the horizontal scale came
from the group width. On a group that is not shaped like the screen that
made the vertical coordinates wrong, so the shader was reading rows the
group does not have. What happens then depends on the GPU. Adreno wraps
around, which is the tiling and the noise band you saw. Mali just smears
the edge instead, which is why it looked fine for some people and broken
for you.
The fix is in for the next update. My test device is Mali so I never got
the exact tiling you had. If you can check once the update is out and tell
me it looks right on the OnePlus, that would help.
