Globals and shortcuts improvement
Organize shortcuts, adding description to shortcuts and flows, shortcut type for globals, labeling (for globals, flows, shortcuts) for better and simpler customization for consumers, putting title, description, min/max value as advanced editing.
Shortcut type global, the name itself is already clear, it’s like shortcuts, but in globals. I know shortcuts section already exist, but you can’t really organize it nor adding a description to explain which does what. While I can still name it by naming the object, the name got CUT OFF so it isn’t very useful. The application to shortcuts would be similar to another value that can be synced to globals by adding global icon when selecting.
Labels would work like title, but only visible in “globals” this would hide the actual title and moving the description under the label.
Advanced editing (for globals), this could be enabled/disabled by default from app settings. The function is to make variable customization easier. This would only show one input box which is the value, and under it would be the ‘advanced editing’ checkbox to edit the title, min/max value, and description. This would make it easier and less confusing for consumers who is very new to Kustom apps, and easier for producers so they don’t have to explain as many.
These features would make theme customization easier for both consumers and producers.
