Global Variable paste issue
so when I copy variables in folder such as variable named “melvis” inside font folder then go back to root location in globals variable → paste, now notice not only the name is “font/melvis2” but looking at name you can see that name character limit has also been bypassed, so what we need for it to function correctly is if you are copying the variable that is from the folder location then when gone to press paste button just display simple dialog of choose “whether to paste variable in current location or create/paste in existing original path” that second choice is where if folder exists of that copied variable then paste inside folder otherwise create that folder and then paste inside newly created folder.
This has been fixed in 3.77, thanks for reporting!
