I’m trying to make a list of fonts so I can choose whatever font I want to use in the watchface itself.
I’ve made a global list containing 8 entries and named fs. All entries being $gv(fx)$ (x = number 1-8).
Then I’ve made 8 seperate global font variables named f1, f2, f3 etc. with set fonts.
But then I also have another global font named fa that has the formula $gv(fs)$ so I can see which font in the list I want to apply. It works.
For example, the chain would be, the list (fs) will look for f1 and grab the font, then send it to fa which would then be used in every text entries throughout my watchface.
The problem is that the global font named fa doesn’t update on its own. I have to set the font and then open up the editor and open global font fa and just hit the checkmark in the top right for it to update. It doesn’t do it on it’s own.
Is there a way I can trigger it to update automatically?
Edit: uploaded a screenshot to further explain what I mean, there you can see how I’ve set it up. fa is never updating unless I open up the formula and then save it from the editor.
Edit 2: Now I’ve tried using[f=gv(fa)][/f] as well to see if that works on all text fields but nothing happens. If I set this formula it will update as soon as I exit the edit screen but if I change between fonts on the watchface itself it doesn’t change.
Want to include also that I’m using arrow buttons to use next/previous entry in the list like this.
Edit 3: Recorded a video of my issue to clarify.
