Get connected bluetooth device's (any) name and battery level
I want to get all connected bluetooth device, but you can only get audio bluetooth device name, same goes to the battery, only audio device. I saw this post but I do not understand a single thing about what they are talking. Using a Samsung note 9
Unfortunately, you can only do this natively with audio devices. The post talks about grabbing the battery info using Tasker. If you can do that then you should be able to send this data to KWGT via broadcast receiver.
Thanks for the reply
