Frame Rate Keeps Changing
I have my frame rate (or “refresh rate” as it’s referred to in the settings) set to “fastest.” When I initially set this value, the frame rate looks good. Over time, though, the frame rate appears to change and get really choppy. I then have to go back into the app and change the setting to something else and then back to “fastest” in order to get a smooth, high refresh rate back.
Thanks for reporting the issue, Is this happening on 3.80 or 3.79?
I have the same issue for some time. I kept having to go into settings and change the refresh rate between 120 and fastest. I’m on version 3.79. I don’t see any update to 3.80 on play store.
would you mind testing latest 3.80 at Downloads | Kustom HQ and see if thats still an issue ??
It appears to be fine for me now. Although I also did some optimization like reducing the image and object sizes so maybe that helped.
