I'm trying to limit the scrolling of one komponent depending on a global. I'm using the following formula: $if(gv(carro)=1,168,336)$
But the limit only works with 168. If the global gets deactivated, it still limits only to 168 and the animation stops halfway.
If I open klwp, deactivate the global and save, it will now only use the 336 limit. Making the animation go farther away than required.
Is there a workaround? I'm I doing something wrong?
