In complex animation you can only input static number. It would be helpful if you can use formula with some syntax (similar to how svgpath works). This way the complex animation can be based on some value. I understand that maybe kustom only calculate the value when saving, but it still helpful in some cases like when making things based on si(mindex). Making staggered animation will be much easier if this enabled.
