Fonticons showing up as a question mark
Hello Kustom team,
Please check the attached screenshot. When I am trying to add any fonticon, even from the default available fonticon packs in the app, it still is showing up as a question mark and I am unable to select any icons.
Please help at the earliest as my entire homescreen is having to be kept blank now since all icons are being showed up as a question mark.
With regards,
Mahesh Iyer
I'm having the same problem. Brand new Samsung phone, Android 10. I've uninstalled and reinstalled kwgt.
The four pre-installed icon fonts all show a question mark - some of them the icon picker works, some of them out doesn't - it just shows up with unknown.
I've installed several other icon fonts and none of them work either I'm on version 3.49
Hi Glenn,
It appears to be a bug with the version. This was clarified to me by the Kustom Team, thanks to Frank and you can download the fixed version fr the following link.
https://kustom.rocks/downloads
Thanks! :)
