Flow group not showing up
Hello,
I was always a heavy user of a widget called Nils, it was primarily a lock screen widget but also had a very nice homescreen widget that allowed for at a glance interaction with all unaddressed notifications. It was scrollable, provided direct interation as far as being able to reply and close notifications directly from the widget, and when there were no new notifications, the widget was invisible.
That widget is discontinued, and I’m trying to recreate the functionality in Kustom. Apparently I need a control called “Flow group”, but it does not show up when go into my add screen. I’ve spent a couple hours of trouble shooting with grok, mulipte reinstalls, trying different launchers, tried sideloading 3.73…and there is no joy.
Is this a common issue people are seeing with the S25/One UI? Or am I special?
Thank you! Let me know if there is any other info I can provide. Advice is much appreciated.
It would be better if you could provide us screenshot(s) of this Nils widget, and a brief description about its features/functions, or the goals you want to achieve with a widget like this Nils.
This would help us to guide you.
