Kazuma
1
It Is many monthe that Inhage reported this issue.
I was Just wondering if someone would like to fx It.
On the Watch side i moved to Watchmaker that manager steps correctly, but i have mo alternative for KLWP.
Pressing fix Is prompting me the same modal
thanks
regards
KZM
Ace
2
This is actually a known issue. Last I checked, this is already being worked on so make sure that you have the latest version of KLWP installed.
Kazuma
3
Hello.
Yes i have the latest Version. The full versione Number in the app Is exactly the same of the versione in the Google Play Store.
All permissions are ok. Checked them.
Regards
KZM
Ace
4
If you don’t have 3.77b435216, sideload it from the official download page.
Kazuma
7
Hello.
No news on this?
Ignored as usual’?
Regards
KZM
Ace
8
I’m no longer able to reproduce this issue. Try to clear the app’s cache and see if that helps. If not, I suggest a clean install.
Kazuma
9
Ho.
I did this already, but to be sure this Is what i have done right now:
- force stop
- cache data cleanup
- application data cleanup
- uninstall app
- backed up my actual KLWP file
- cleanup wallpaper dir
- remove from Google fit/health all permissions leftover to kwlp.
- installed latest version from Google Play
- configured
- get One of th preset
- added step count
- on th modal box i tap on “Fissa” (fun translation btw)
- grant full permissions
And I get the exact same issue: the modal box oa keep asking me to fix
Google Pixel Pro 8, android 15
Do you know other app that do the same thing as kwlp?
For KWCH i moved to Watchmaker.
And yes, keep the 5+5 € i have you. Maybe in the future you Will care about users.
Regards
KZM
Ace
10
Did you try renaming/deleting the entire Kustom folder, of course after backing it up, to make sure that you’re starting from scratch?
Kazuma
11
Hello.
Yes, my point 5 was that
I moved all the kwlp file in a different Folger end empiedd the kustom folder completely.
Regards
KZM
Having the same issue, also after Clearing data, folders and fresh Install.
Even lost all my widgets in the process (faulty Backup), the issue persists.
Ace
13
A new beta is out. You may want to test that.
