Finding and adding Komponents to KWGT
Hi
I’ve used KWGT for several years and love it. However, I like to make my own widgets but base them on the packs I already own.
Up until recently, I just made do with the inbuilt Komponents for weather and such, but I recently decided to start trying something new. My only problem is that I can’t find ways to use the Komponents (weather, battery, etc.) from other widgets and, so far, have only been able to find one downloadable Komponent app, as the rest want me to download full widgets.
I wouldn’t have a problem downloading the full widget if I could use the Komponent, but that just doesn’t happen. Is anyone able to tell me how I get the Komponents from one widget onto another and/ or point me in the direction of Komponents and Komponent apps?
Any help is much appreciated.
This is real problem for sure because sometimes komponents comes with lock that creates hassle if you have it inside the kwgt which is also locked. one thing i would say I have heard that you can convert .kwgt file to komponent file just by changing the file extension to .Komp Now if you want to move komponent from the one widget to another you have 3 ways, No 1. by copy-paste. (komponent shouldn’t be locked) No 2. is by exporting komponent which is done by archive box icon between restore button and lock button while inside the komponent but it will only show up when author has komponent unlocked so no locked komponent will work if you want to get that you might have to delete everything else in widget root and only keep komponent and change extension as mentioned above. and third route is limited similar to 2nd method which probably won’t work and is time consuming, for this you have to either open komponent containing .kwgt file as archive (either change extension to .zip and extract or open as archive in mixplorer (similar in other file opening app menu)) then open preset.json and search for “KomponentModule” and you might find more than one if you have more than one komponents inside the .kwgt file but you should be able to identify it by looking at “internal_title” string pair value and that block of Json code is komponent but if you can do this then it means you can try 2nd method so why try this lengthy method at all? I don’t know i just threw it to say method exists but only for unlocked komponents.
