Reproduction steps:
- Create a text global:
test - Create a flow
- Trigger > Manual
- Action > Formula:
$df(S)$ - Action > Set Global Var:
test, Mode: Write file
- Add a text element:
$wg(gv(test), raw)$ - Trigger the flow
Expected: The text element should display the value set in the flow.
Actual:
err: java.io.ioexception: unable to read file: /data/user/0/org.kustom.wallpaper/cache/flows/[id]/[id].task
