Error touches on grid 5x9 xiaomi
Hi. I’ve used KWGT for at least 2 month on my new Xiaomi 15t pro with no problems, i used only simply images for launching my apps (a workaroud because xiaomi can’t change icon pack) , now i noticed that if you change the grid of xiaomi launcher the app doesn’t respond correctly , i click on an icon ed opens an other thing , if i switch to old grid (4x7) it works as intented, i have already done the test , every icon is in the right place and in the demo works everything as intended.
the error happens expecially with my second to left icon, when i touch that it opens the leftmost icon and also in the other part of the screen (the rightmost part), usually my center app always works good.
Device Xiaomi15t pro
Android 16 Xiaomi HyperOS 3
Looks like HyperOS launcher doesn’t properly adapt the touch hitboxes when you switch to a dense 5×9 grid.
I tested it on my own Xiaomi and the same thing happens taps get shifted even though everything is placed correctly in KWGT.
With the default 4×7 grid it works fine, so it’s probably a launcher issue rather than a KWGT issue.
So is impossible for Kustom to do something about this?
Honestly, there’s nothing Kustom can do about this. I’ve tested it myself: inside the KWGT editor, all touch zones work perfectly regardless of the grid. The hitboxes only shift once you’re on the home screen.
It’s 100% a HyperOS launcher bug it fails to scale the widget’s touch layer properly on a 5x9 grid. Your only real options are:
Go back to the 4x7 grid.
Switch to a third-party launcher (like Nova or Niagara) that handles custom grids correctly.
