When I click on a widget to redo it on my home screen it pulls up the main editor and I try to load a preset change the design but none of them are there on the app and I have kwgt pro…and I’ve tried uninstalling it and installing it back and nothing works, I’m stomped on what to do, anyone know what I need to do?
Are you referring to presets you installed from the Play Store? If yes, have you tried loading them directly from the preset app?
