I’d like to share another one of my more advanced components — a fully dynamic Sunrise/Sunset komp built entirely on math formulas and coordinate calculations.
How it work The Sun moves along an arc from sunrise to sunset After sunset, the Moon appears and travels the opposite arc Full real-time motion based on actual sunrise/sunset times for your location
In Globals you can adjust color and opacity.
I’ll attach a screenshot showing how it looks inside a widget — but you can integrate however you like.
Copy/move the downloaded file to your phone, into the Komponents folder (under your Kustom installation folder)
Add a new blank widget on your homescreen
Tap on the new blank widget to open the KWGT editor
On the KWGT editor, insert a new element (the Komponent type), and select the Komponent you want to use (in this case, Max’s dynamic Sunrise/Sunset komponent).
