This is one of the Pixel Android 14 clocks. I have a new Android 14 phone I would like to use this lock screen. The phone is NOT rooted as the ROM is not available for recovery purposes.
Any tips on how to create this would be most appreciated.
You need the KLCK app for this.
Used KLCK as you suggested and created a lock screen and now the screen I created has locked up the phone and I cannot get it to boot into recovery to wipe it!
The usual power & up volume keys do not get me into recovery.
Any ideas? I am stumped.
Thanks.
Went into safe mode and deleted the app. Phone now unlocked but going to use a spare to figure out why I got locked out in the first place.
Awesome! I’m glad you have this all sorted out.
If you made a mistake in you KLCK preset and you can’t normally unlock it you can unlock it by long pressing bottom right corner (some report bottom left, but I think it’s bottom right).
Thanks for the tip. My issue is that the lock screen works, but it locks up the phone! I can usually open one app and then the phone will not scroll between screens or open another app. I must then reboot and revert to the original lock screen and then the phone works as normal. Maybe the next version of KLCK will resolve this.
Issue resolved. Third party launcher was the problem. Reverted to stock launcher and everything is working as expected.
