Dot klwp file contents map
In other words it appears the the DOT klwp file is simply a container.
Also where is the actual theme data stored in the Android file system hierarchy and the files stored there (for example XML files, what)??
THAT is the actual info I'm looking for. THANKS
OK, did my OWN research. A klwp file is actually a zip file. The main file contained within it is a JSON files name preset.JSON. Other supporting files are images, bitmaps, etc within the container file
