How to check that DND is on or off, if dnd is on then ON and if DND is off then text should show OFF
Unfortunately, not possible with the native formulas. You can probably use shell or use Tasker instead.
Ok Thanks, I hope this would be my another feature suggestion. I hope this would be added in future updates.
