Df() reference page?
@frank : Hi. Is there any reason the df() reference (http://help.kustom.rocks/i146-df-format-a-date-into-text) page no longer exists? I know you can’t fit all the examples into the Kode text so I thought it was useful. Just asking.
Thanks for all your work!
Documentations were migrated to https://docs.kustom.rocks a while back. df() reference should be at DF - date format | Kustom HQ
Thanks Ace, I should have known that. I just had the old link in bookmarks and it doesn’t forward.
You can also use the shortcut:
This always redirect to the right page (as it did in the past)
Unfortunately Google doesn’t index that
Thank you. It was the o and zZ arguments I couldn’t remember without the references.
