Hello
Why do KWGT icons have a different shape and are smaller than all the icons on my desktop?
KWGT’s are actually widgets and not app icons, so they may look different than regular icons. First, check if your launcher supports changing widget shapes. If this roundness is by KWGT design, you can generally change the roundness of a shape within KWGT by changing the “Corners” attribute’s value, if that’s what the author used.
