This is for KWGT v3.74 on a Lenovo Tab P12, android version 13.
I want to display a timestamp when I press an on-screen button, and each button needs its own independent timestamp. So, I have 2 buttons, 1 to toggle global switch ts1, and the other to toggle global switch ts2. Both globals are $df(MMMM d hh:mm)$. Button 1 has a corresponding text box with $gv(ts1)$, and button 2 has its own text box with $gv(ts2)$.
The problem is that whichever button I press, it updates the timestamp in both text boxes. Also, when I am in editing mode, the text boxes run like a clock instead of showing static times. Is toggling a global variable (text) not the way to go about this? Is having the same formula as 2 globals messing things up?
I imported your komponent and it works just fine! Thank you! I also built the flow like you described, and that worked as well. I appreciate your help. I’m re-installing KWGT just in case it’s a weird bug
