Create a vertical widget 1x4
Hi all
I am trying to create a vertical widget 1x4 similar to the 4x1 widget. I dont find a way to do this. Can anybody help me please?
Thanks and cheers
Marco
Hi Marco, sure! To create a 1x4 widget do the following:
  • Add a 1x1 widget dragging it on your screen
  • Long press on it, then drag the borders to make it 1x4
  • Click on it to start the configuration and load a preset
If you already loaded a preset
  • Long press on the widget
  • Resize it to that dimensions
  • Click on it in order to start the config or click on the background area if you do not have the config associated
  • Open the editor and use the Layer -> Scale option to make it fit (unless you have autoscale option set to on)
Hope it helps.
Hi Frank
Yes, thank you :) That works perfectly. Just bought your great App!
Thanks! Welcome to Kustom!!
