Crash on delete
this issue i tested in both kwgt(3.76b422110) and klwp(3.76b422110) and both app crashes same way. I’ll try to include more relevant info below so it’s easier for dev
reproduce steps:-
  1. create folder in global tab
  2. add any types of 3 items in that folder (important)
  3. go back to root in globals
  4. try to delete folder (app crashes)
step no. 2 is important because if i try to delete folder with no items inside than that folder gets deleted, and app don’t crash so it is safe to assume app crashes because of items inside it.
at the moment i only use klwp and kwgt, however based on behavior of both apps I might have doubts on that issue exists across the klck and kwch app as well.
I can reproduce this. This is actually a known issue and I believe @frank is already aware of this.
okay then i’ll make sure to avoid reporting for future versions
This is fixed in 3.77
