Contador de widgets editados
Alguien puede explicarme como borrar el contador de widgets editados y que regrese a cero?
Could you please explain exactly which counter you are referring to? Maybe share a screenshot?
Also, please write in English if possible, so other users can understand the issue and the solution!
Hi @Graciela1310 ,
I would suggest you to always post on English so that most of us here can understand and hopefully can have any solutions.
The number you asked about is automatically set by the app and cannot be overridden nor reset by the user.
Thanks for the screenshot, now I understand what you meant.
Widget 5987 that’s not a counter of how many times you’ve edited your widgets. It’s just the default name assigned to your current preset.
Kustom automatically numbers unnamed widgets. To change this, you just need to rename your widget when exporting or saving it. There is no reset to zero because it’s not a counter, it’s just a file name!
