I installed the beta and unfortunately it didn’t work.
Furthermore, the connected BT device is only shown to me when I start another app. If I disconnect the BT device, the changed status is immediately displayed.
I just don’t understand why that is. Is that only for me that way? I can’t find any other complaints about it on the internet.
May I have the make and model of your device? Also, is it possible for you to share a sample preset that demonstrates this issue for you so we can try to reproduce it?
When I read your message, I was in a friend’s car and connected my smartphone to the car via Bluetooth. The car as a BT device is displayed immediately.
So does the problem generally exist with earbuds headphones?
Earbuds and headphones should be supported. I tested your preset on earbuds and it worked just fine. Could be a compatibility issue with this specific device.
