Hello,
I found the compass option in the app, but I find it confusing to use.
Ater choosing a Gyroscope Animation, I find Compass option under Axis.
How does this work?
I see Brandon Craft has a tutorial about it over on YouTube, haven’t watched it myself, but I’m pretty sure that’ll be helpful. Bare in mind that his tutorials are all somewhat older, so some things might have changed in Kustom, but the big picture should be the same.
Try downloading this theme and checking the code
Maybe I posted in the wrong forum? My issue is with the watch face app.
Not the wrong forum…
You can download Kylde’s preset and change the file extension from .KLWP to .KWCH and it will run on your watch or you can import to the KWCH app and view the code there or in the KLWP app. No difference.
I had a similar issue a while back where the needle just wouldn’t budge. Have you checked if the phone’s actual magnetometer is calibrating correctly outside of the app? I usually use 123compass org on my mobile browser to see if the raw sensor data is picking up anything. If it works there but not in Kustom, it might be a permissions or polling rate issue in the app settings.
